주요 콘텐츠로 건너뛰기
Removing HP Compaq dx2000MT Case Fan
필요한 것
  1. Removing HP Compaq dx2000MT Case Fan, Removing the HP Compaq dx2000MT Case Doors: 1 단계, 이미지 1/1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Removing HP Compaq dx2000MT Case Fan: 2 단계, 이미지 1/2 Removing HP Compaq dx2000MT Case Fan: 2 단계, 이미지 2/2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Removing HP Compaq dx2000MT Case Fan: 3 단계, 이미지 1/3 Removing HP Compaq dx2000MT Case Fan: 3 단계, 이미지 2/3 Removing HP Compaq dx2000MT Case Fan: 3 단계, 이미지 3/3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Removing HP Compaq dx2000MT Case Fan: 4 단계, 이미지 1/3 Removing HP Compaq dx2000MT Case Fan: 4 단계, 이미지 2/3 Removing HP Compaq dx2000MT Case Fan: 4 단계, 이미지 3/3
    • Once again, this may take considerable force.
  5. Removing HP Compaq dx2000MT Case Fan, Case Fan: 5 단계, 이미지 1/3 Removing HP Compaq dx2000MT Case Fan, Case Fan: 5 단계, 이미지 2/3 Removing HP Compaq dx2000MT Case Fan, Case Fan: 5 단계, 이미지 3/3
    • Remove the 3 prong power connector from the motherboard by pulling it outwards toward the side of the device.
  6. Removing HP Compaq dx2000MT Case Fan: 6 단계, 이미지 1/3 Removing HP Compaq dx2000MT Case Fan: 6 단계, 이미지 2/3 Removing HP Compaq dx2000MT Case Fan: 6 단계, 이미지 3/3
    • Remove the 4 push fasteners from the case by:
    • Prying them outwards with a small flathead screwdriver and
    • Pulling them out with tweezers or plyers.
  7. Removing HP Compaq dx2000MT Case Fan: 7 단계, 이미지 1/3 Removing HP Compaq dx2000MT Case Fan: 7 단계, 이미지 2/3 Removing HP Compaq dx2000MT Case Fan: 7 단계, 이미지 3/3
    • Remove the fan from the case by pulling it towards the front of the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Logan Pace
회원 가입일: 10/12/11
2,224 평판
안내서 9개 작성하였습니다
Cal Poly, Team 17-16, Regan Fall 2011 Cal Poly, Team 17-16, Regan Fall 2011 회원
CPSU-REGAN-F11S17G16
4 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 14
전체 시간: 2,674
