이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn off your computer and remove the power cable by pulling it straight out of its socket.
Remove the two Phillips #2 screws that secure the case door to the device.
Remove the side case door by pushing towards the rear of the device with your hand.
Once you slide the door back, remove it by pulling it outwards from the device.
Remove the 3 prong power connector from the motherboard by pulling it outwards toward the side of the device.
Remove the 4 push fasteners from the case by:
Prying them outwards with a small flathead screwdriver and
Pulling them out with tweezers or plyers.
Remove the fan from the case by pulling it towards the front of the device.
다른 3명이 해당 안내서를 완성하였습니다.
