주요 콘텐츠로 건너뛰기
Removing HP Compaq dx2000MT Power Supply
필요한 것
  1. Removing HP Compaq dx2000MT Power Supply, Removing the HP Compaq dx2000MT Case Doors: 1 단계, 이미지 1/1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Removing HP Compaq dx2000MT Power Supply: 2 단계, 이미지 1/2 Removing HP Compaq dx2000MT Power Supply: 2 단계, 이미지 2/2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Removing HP Compaq dx2000MT Power Supply: 3 단계, 이미지 1/3 Removing HP Compaq dx2000MT Power Supply: 3 단계, 이미지 2/3 Removing HP Compaq dx2000MT Power Supply: 3 단계, 이미지 3/3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Removing HP Compaq dx2000MT Power Supply: 4 단계, 이미지 1/3 Removing HP Compaq dx2000MT Power Supply: 4 단계, 이미지 2/3 Removing HP Compaq dx2000MT Power Supply: 4 단계, 이미지 3/3
    • Once again, this may take considerable force.
  5. Removing HP Compaq dx2000MT Power Supply, Power Supply: 5 단계, 이미지 1/3 Removing HP Compaq dx2000MT Power Supply, Power Supply: 5 단계, 이미지 2/3 Removing HP Compaq dx2000MT Power Supply, Power Supply: 5 단계, 이미지 3/3
    • Remove the 4 pin ATX power connector from the motherboard by pressing down the holding latch and pulling out towards the side of the device.
  6. Removing HP Compaq dx2000MT Power Supply: 6 단계, 이미지 1/2 Removing HP Compaq dx2000MT Power Supply: 6 단계, 이미지 2/2
    • Remove the 20 pin ATX power connector from the motherboard by pressing down the holding latch and pulling out towards the side of the device.
  7. Removing HP Compaq dx2000MT Power Supply: 7 단계, 이미지 1/3 Removing HP Compaq dx2000MT Power Supply: 7 단계, 이미지 2/3 Removing HP Compaq dx2000MT Power Supply: 7 단계, 이미지 3/3
    • Remove the 4 Torx T15 screws from the rear of the power supply
  8. Removing HP Compaq dx2000MT Power Supply: 8 단계, 이미지 1/2 Removing HP Compaq dx2000MT Power Supply: 8 단계, 이미지 2/2
    • Slide the power supply towards the front of the device
    • Keep your hand underneath it! You don't want to drop it!
    • Then pull the power supply down and remove it from the case.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Logan Pace
회원 가입일: 10/12/11
2,224 평판
안내서 9개 작성하였습니다
Cal Poly, Team 17-16, Regan Fall 2011 Cal Poly, Team 17-16, Regan Fall 2011 회원
CPSU-REGAN-F11S17G16
4 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 25
전체 시간: 3,363
