주요 콘텐츠로 건너뛰기
Removing HP Pavilion zd8000 WiFi Card Cables
필요한 것
  1. Removing HP Pavilion zd8000 WiFi Card Cables, Battery: 1 단계, 이미지 1/1
    • Slide the battery release latch towards you.
  2. Removing HP Pavilion zd8000 WiFi Card Cables: 2 단계, 이미지 1/2 Removing HP Pavilion zd8000 WiFi Card Cables: 2 단계, 이미지 2/2
    • Pull up on the battery to remove it.
  3. Removing HP Pavilion zd8000 WiFi Card Cables, WiFi Card Cables: 3 단계, 이미지 1/2 Removing HP Pavilion zd8000 WiFi Card Cables, WiFi Card Cables: 3 단계, 이미지 2/2
    • Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs.
    • Lift the cover from the right to remove it.
  4. Removing HP Pavilion zd8000 WiFi Card Cables: 4 단계, 이미지 1/2 Removing HP Pavilion zd8000 WiFi Card Cables: 4 단계, 이미지 2/2
    • Use tweezers to detach the grey and black cables connected to the green WiFi card.
결론
Allie Menard
회원 가입일: 04/12/11
820 평판
안내서 13개 작성하였습니다
Cal Poly, Team 24-56, Amido Spring 2011 Cal Poly, Team 24-56, Amido Spring 2011 회원
CPSU-AMIDO-S11S24G56
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 3,345
