주요 콘텐츠로 건너뛰기
Removing JuiceBox from the wall
  1. Removing JuiceBox from the wall, Remove mounting screw: 1 단계, 이미지 1개 중 1개
    • On most installations, the JuiceBox is held to your wall using one screw between the two cable glands. Remove this screw.
    • After removing the mounting screw, lift JuiceBox straight up (parallel to wall) to unlatch it from the wall mounting tab. If you ever sell/give away JuiceBox, keep this wall mount tab with the box!
    • If your JuiceBox is hardwired, you would instead replace these steps with simply switching-off the breaker in preparation for the relay replacement work. To remove a hardwired unit from the wall, consult an electrician.
결론
작성자
2다른 기여자 명과 함께
Matt Falcon
회원 가입일: 05/09/15
2,740 평판
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 33
전체 시간: 1,023
