주요 콘텐츠로 건너뛰기
Removing Lenovo Thinkpad T61p RAM
필요한 것
  1. Removing Lenovo Thinkpad T61p RAM, RAM: 1 단계, 이미지 1/2 Removing Lenovo Thinkpad T61p RAM, RAM: 1 단계, 이미지 2/2
    • Place the laptop on a fat surface with the underside facing up
    • Remove the 4 Philips head screws.
    • Turn the computer over and open the display
    • Grasping each side of the palm rest, gently lift it off and rotate toward the front of the laptop
    • The palm rest will be connected to the main board by a ribbon cable
  2. Removing Lenovo Thinkpad T61p RAM: 2 단계, 이미지 1/1
    • Disconnect the touchpad ribbon cable
    • This step is recommended in the service manual however it is possible to remove the RAM without discoinnecting the touchpad cable
  3. Removing Lenovo Thinkpad T61p RAM: 3 단계, 이미지 1/1
    • Locate the RAM modules
    • Gently press the metal tabs outwards to release the top RAM module and remove it from the laptop
    • With the top RAM module removed you can release the lower RAM module in the same manner.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Glac1er
회원 가입일: 05/25/13
180 평판
안내서 1개 작성함
Glac1er Glac1er 회원
Community
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 11
전체 시간: 9,946
