주요 콘텐츠로 건너뛰기
Removing Minolta X-370 Bottom Cover
필요한 것
  1. Removing Minolta X-370 Bottom Cover, Minolta X-370 Battery Replacement: 1 단계, 이미지 1/2 Removing Minolta X-370 Bottom Cover, Minolta X-370 Battery Replacement: 1 단계, 이미지 2/2
    • Flip the camera so that the bottom is facing you.
    • Take a spare coin and unscrew the battery cover off.
  2. Removing Minolta X-370 Bottom Cover: 2 단계, 이미지 1/1
    • Remove the batteries, making sure to note their proper alignment.
    Hi just checking which type of batteries are required? You have two types listed, the SR44/LR44 (I understand those are the same types of batteries) then the CR-1 / 3 /3N 3V battery? How many batteries do I need and which type will I need? thanks!
    Juliette Perry-Dumarquez - 답글
  3. Removing Minolta X-370 Bottom Cover, Bottom Cover: 3 단계, 이미지 1/2 Removing Minolta X-370 Bottom Cover, Bottom Cover: 3 단계, 이미지 2/2
    • Remove two 4.8mm screws.
    • Remove one 3.4mm screw.
    • Remove one 2.65mm screw.
    • Lift off the back cover.
  4. Removing Minolta X-370 Bottom Cover: 4 단계, 이미지 1/1
    • Remove three 3.5mm screws.
    • Remove two 3.8mm screws.
    • Remove one 6.35mm screw.
    • Remove one 4mm screw. Lift off the disk.
    • Remove one 5.11mm screw.
  5. Removing Minolta X-370 Bottom Cover: 5 단계, 이미지 1/1
    • Lift up the silver, metal piece
    • Please note that some internal pieces may come loose during this process.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Nick
회원 가입일: 04/19/11
525 평판
안내서 4개 작성하였습니다
Cal Poly, Team 8-7, Regan Spring 2011 Cal Poly, Team 8-7, Regan Spring 2011 회원
CPSU-REGAN-S11S8G7
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
good advice, will use, have multiple Minolta cameras to work with.
gabriel johnson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 34
전체 시간: 10,779
