메인 콘텐츠로 스킵하기
소개
You will be removing some leather grips, which you will reuse, to access some screws. Be careful not to tear these grips.
부품
지정된 부품이 없습니다.
  1. Flip the camera so that the bottom is facing you. Take a spare coin and unscrew the battery cover off.
    • Flip the camera so that the bottom is facing you.
    • Take a spare coin and unscrew the battery cover off.
  2. Remove the batteries, making sure to note their proper alignment.
    • Remove the batteries, making sure to note their proper alignment.
  3. Remove two 4.8mm screws. Remove one 3.4mm screw.
    • Remove two 4.8mm screws.
    • Remove one 3.4mm screw.
    • Remove one 2.65mm screw.
    • Lift off the back cover.
  4. Remove three 3.5mm screws.
    • Remove three 3.5mm screws.
    • Remove two 3.8mm screws.
    • Remove one 6.35mm screw.
    • Remove one 4mm screw. Lift off the disk.
    • Remove one 5.11mm screw.
  5. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  6. Lift up the silver, metal piece
    • Lift up the silver, metal piece
    • Please note that some internal pieces may come loose during this process.
  7. Remove four 4.45mm screws and remove the alignment ring. Remove the interior metal ring and the black plastic ring.  Pay attention to the spring's location. Pay attention to the alignment of the interior metal ring and the black plastic ring.
    • Remove four 4.45mm screws and remove the alignment ring.
    • Remove the interior metal ring and the black plastic ring. Pay attention to the spring's location.
    • Pay attention to the alignment of the interior metal ring and the black plastic ring.
  8. Remove the two black stoppers. Using the metal spudger, remove the two triangular hangers. Using the metal spudger, remove the two triangular hangers.
    • Remove the two black stoppers.
    • Using the metal spudger, remove the two triangular hangers.
  9. Using the metal spudger, peel off the right leather cover. Be careful not to tear the cover because you will need to use it again.
    • Using the metal spudger, peel off the right leather cover.
    • Be careful not to tear the cover because you will need to use it again.
  10. Use the metal spudger to remove both the grip cover and the left leather cover. Be careful not to tear the covers because you will need to use them again. Be careful not to tear the covers because you will need to use them again.
    • Use the metal spudger to remove both the grip cover and the left leather cover.
    • Be careful not to tear the covers because you will need to use them again.
  11. Remove two 5.3mm screws. Remove two 5.3mm screws.
    • Remove two 5.3mm screws.
    • Remove one 2.35mm screws.
  12. Remove the left and right plastic covers. Remove the left and right plastic covers.
    • Remove the left and right plastic covers.
  13. Remove two 6.65mm screws. Remove two 2.93mm screws. Remove four 5.3mm screws.
    • Remove two 6.65mm screws.
    • Remove two 2.93mm screws.
    • Remove four 5.3mm screws.
    • Remove the black plastic lens holder.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Nick
회원 가입일: 2011년 04월 19일
411 평판
안내서 4개 작성하였습니다
Cal Poly, Team 8-7, Regan Spring 2011 Cal Poly, Team 8-7, Regan Spring 2011 회원
CPSU-REGAN-S11S8G7
4 회원들
안내서 4개 작성하였습니다
I have Problems to assemble the new black plastic lens holder.
The space between camera Cup and the housing is very low.
Did someone have the same Problems ?
Klaus Kohlhas - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 29
전체 시간: 5,983
