소개
Step-by-step guide to removing your phone's antenna.
  1. The antenna is located on top right corner of the phone while the front of the phone is facing you. Unscrew the antenna clockwise until it is loose enough to remove from the phone. Unscrew the antenna clockwise until it is loose enough to remove from the phone.
    • The antenna is located on top right corner of the phone while the front of the phone is facing you.
    • Unscrew the antenna clockwise until it is loose enough to remove from the phone.
  2. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
결론
Elizabeth OBrien
회원 가입일: 2010년 04월 26일
31 평판
안내서 7개 작성하였습니다
Cal Poly, Team 30-40, Garner Spring 2010 Cal Poly, Team 30-40, Garner Spring 2010 회원
CPSU-GARNER-S10S30G40
4 회원들
안내서 14개 작성하였습니다
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 10
전체 시간: 2,915
