소개
Is your phone having trouble receiving signals? Then your antenna may need to be replaced.
This is a step-by-step guide to replacing a Motorola V60i phone antenna.
Before replacing phone’s antenna, make sure the phone is powered down.
The antenna is located on top right corner of the phone while the front of the phone is facing you.
Unscrew the antenna clockwise until it is loose enough to remove from the phone.
다른 한 분이 해당 안내서를 완성하였습니다.
