주요 콘텐츠로 건너뛰기
Removing Nikon Coolpix 4600 Front and Rear case
필요한 것
  1. Removing Nikon Coolpix 4600 Front and Rear case, Front and Rear Case: 1 단계, 이미지 1/2 Removing Nikon Coolpix 4600 Front and Rear case, Front and Rear Case: 1 단계, 이미지 2/2
    • Locate the six screws on the outside of the camera (2 3.3 mm on the bottom, 2 5.25 mm on the left, and 2 5.25 mm on the right).
    • Using a Phillips 00 screwdriver, remove all of the six screws.
  2. Removing Nikon Coolpix 4600 Front and Rear case: 2 단계, 이미지 1/2 Removing Nikon Coolpix 4600 Front and Rear case: 2 단계, 이미지 2/2
    • Carefully pull the front and back case apart.
    • The front case is attached to internal components and cannot be removed independently.
  3. Removing Nikon Coolpix 4600 Front and Rear case: 3 단계, 이미지 1/1
    • Look closely at the connection between the ribbon cable and the motherboard. Locate the two grey tabs on either side of the connecting bracket.
    • Slide the grey tabs toward the bottom of camera. Gently disconnect the ribbon cable from the motherboard.
    • After disconnecting the data ribbon, you can now separate the back case from the front case.
결론
Nathan Sperling
회원 가입일: 05/08/12
119 평판
안내서 4개 작성하였습니다
Cal Poly, Team 9-43, Regan Spring 2012 Cal Poly, Team 9-43, Regan Spring 2012 회원
CPSU-REGAN-S12S9G43
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 1,481
