소개
This guide has been updated by iFixit staff! Read the new, official guide here.
This guide will show you how to remove the screws that hold the Logic Board into place. From here, some repairs may be done that require you disconnect all connected modules, and some may not require that you disturb the connections.
필요한 것
Place your device upside down and locate the battery compartment.
Find the Phillips head screw securing the battery cover in the bottom right hand corner of the device.
Remove the following seven screws that secure the lower case to the DS Lite:
Three silver tri-wing screws (5mm long)
One black tri-wing screw (4mm)
Two gold Phillips screws (4mm)
One silver Phillips screw (3mm)
Do not remove the silver PH screw (3mm) in the battery compartment yet. It holds the main PCB in place.
Flip the unit over so that it is facing right-side up.
Use a spudger to pry open the gap between the bottom case and the front panel. Work all the way around the case until the panel is free.
Avoid touching the L and R shoulder buttons, because they easily detach and are difficult to reassemble. Keep the bottom case flat against your workbench to help hold the shoulder buttons in place.
After taking the bottom case off, remove two Phillips #00 screws that secure the logic board to the plastic case.
다른 한 분이 해당 안내서를 완성하였습니다.
