주요 콘텐츠로 건너뛰기
Nokia 3100b Screen Replacement
필요한 것
  1. Nokia 3100b Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure your phone is turned off.
  2. Nokia 3100b Screen Replacement: 2 단계, 이미지 1/1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Nokia 3100b Screen Replacement, SIM Card: 3 단계, 이미지 1/1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
  4. Nokia 3100b Screen Replacement: 4 단계, 이미지 1/1
    • Retrieve your SIM card.
  5. Nokia 3100b Screen Replacement, Screen: 5 단계, 이미지 1/1
    • Separate the front cover from the main body of the phone.
  6. Nokia 3100b Screen Replacement: 6 단계, 이미지 1/1
    • Remove the six screws along the edges of the phone.
  7. Nokia 3100b Screen Replacement: 7 단계, 이미지 1/1
    • Pull the screen assembly from the base of the phone.
  8. Nokia 3100b Screen Replacement: 8 단계, 이미지 1/1
    • Carefully lift the keypad portion of the screen assembly from the circuit board.
  9. Nokia 3100b Screen Replacement: 9 단계, 이미지 1/1
    • Separate the screen from the circuit board.
    • Reconnect the ports during reassembly or the screen will not function properly.
    • Remember to reconnect the screen to the circuit board when reassembling!
  10. Nokia 3100b Screen Replacement: 10 단계, 이미지 1/1
    • Gently push down on the screen to pop it off of the assembly.
  11. Nokia 3100b Screen Replacement: 11 단계, 이미지 1/1
    • When the screen falls out the assembly, two white tabs will fall out with it.
    • When reinstalling the screen, insert the tabs with the slanted side pointing upwards so they slide into the assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sterling Fuentes
회원 가입일: 04/09/10
130 평판
안내서 8개 작성하였습니다
Cal Poly, Team 29-64, Johann Spring 2010 Cal Poly, Team 29-64, Johann Spring 2010 회원
CPSU-JOHANN-S10S29G64
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 1,776
