메인 콘텐츠로 스킵하기
소개
Use this guide to cut off numerical keypad from your keyboard.
Why do this?
If you spend a lot of time typing and are experiencing pain in your right shoulder, numerical keypad may be the cause of your pain. When working with your mouse, your right hand is awkwardly positioned far right because of the useless numerical keypad.
There are myriad short keyboards on the market, but almost none retain the regular layout for insert/home/delete/arrows. This hurts me as much as my shoulder.
  1. You can do this with most keyboards.  I had an older Dell keyboard model L100.
    • You can do this with most keyboards. I had an older Dell keyboard model L100.
  2. Turn the keyboard over and you will see 15 screws. Remove them.
    • Turn the keyboard over and you will see 15 screws. Remove them.
  3. Take the keyboard apart. You will find a white rubber sheet under the top part of the keyboard. Cut off the part for the numerical keypad.
    • Take the keyboard apart. You will find a white rubber sheet under the top part of the keyboard. Cut off the part for the numerical keypad.
  4. Fasten the top part of the keyboard and take the hacksaw to it. Cut off the numerical keypad part. Do not use power tools because you may produce toxic fumes and even activate fire alarm.
    • Fasten the top part of the keyboard and take the hacksaw to it. Cut off the numerical keypad part. Do not use power tools because you may produce toxic fumes and even activate fire alarm.
  5. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  6. On the bottom part of the keyboard, remove the three screws and the metal bar holding the keyboard PCB and fold the plastic sheet so it is out of your way when cutting.
    • On the bottom part of the keyboard, remove the three screws and the metal bar holding the keyboard PCB and fold the plastic sheet so it is out of your way when cutting.
  7. Now mark the bottom part of the keyboard for another cut.
    • Now mark the bottom part of the keyboard for another cut.
  8. Cut the bottom part of the keyboard too.  Fold or remove the plastic PCB out of the way when cutting.
    • Cut the bottom part of the keyboard too. Fold or remove the plastic PCB out of the way when cutting.
  9. Screw the PCB and the metal bar back on.
    • Screw the PCB and the metal bar back on.
  10. Assemble the rest of the keyboard, and fold the plastic sheet under your keyboard.  Do not cut it because it will render the keyboard useless.
    • Assemble the rest of the keyboard, and fold the plastic sheet under your keyboard. Do not cut it because it will render the keyboard useless.
  11. Since you have cut the portion of the keyboard with the supporting leg for tilting, supply it with a new leg. You can use a key from the numerical keypad.
    • Since you have cut the portion of the keyboard with the supporting leg for tilting, supply it with a new leg. You can use a key from the numerical keypad.
  12. Tape the key to the keyboad
    • Tape the key to the keyboad
  13. Presto, you are proud owner of a very geeky looking keyboard with even a piece of the PCB sticking out.
    • Presto, you are proud owner of a very geeky looking keyboard with even a piece of the PCB sticking out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Stanko Vuleta
회원 가입일: 2011년 06월 16일
188 평판
안내서 1개 작성함
This is awesome !!
What kind of saw and sawblade are you using?
rrr - 답글
Manual hacksaw is probably the best choice. Any power tool is liable to burn the plastic and produce fumes which you don't want to be inhaling.
Stanko Vuleta -
Can i do this to an aluminum extended keyboard usb apple?
appleuserfan - 답글
Judging by the position of the cable, the pcb is placed away from the numerical keypad, so I would guess you should be able to do it.
Stanko Vuleta -
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 65
전체 시간: 7,151
