주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Removing Olympus FE-210 Motherboard
필요한 것
  1. Removing Olympus FE-210 Motherboard, Battery: 1 단계, 이미지 1/2 Removing Olympus FE-210 Motherboard, Battery: 1 단계, 이미지 2/2
    • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
  2. Removing Olympus FE-210 Motherboard: 2 단계, 이미지 1/2 Removing Olympus FE-210 Motherboard: 2 단계, 이미지 2/2
    • The batteries will slide right out.
    • When putting new batteries in, make sure they are pointing the right direction.
  3. Removing Olympus FE-210 Motherboard, Front Casing: 3 단계, 이미지 1/3 Removing Olympus FE-210 Motherboard, Front Casing: 3 단계, 이미지 2/3 Removing Olympus FE-210 Motherboard, Front Casing: 3 단계, 이미지 3/3
    • Remove the 7 screws holding the front case in place, with a #00 screwdriver.
    • Six screws are 3.6 mm.
    • The seventh screw is 3.2 mm.
  4. Removing Olympus FE-210 Motherboard: 4 단계, 이미지 1/3 Removing Olympus FE-210 Motherboard: 4 단계, 이미지 2/3 Removing Olympus FE-210 Motherboard: 4 단계, 이미지 3/3
    • Pulling the front case off, requires applying enough strength in the right areas.
    • The front case snaps into place in three places:
    • At the top and bottom of the battery side (opposite of side pictured) of the case.
    • Right in the middle of the DC-in side (side pictured) of the case.
    • Top of the camera, to the left of the power button.
    • Once those places are disconnected, the front case will pop right off.
    • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
  5. Removing Olympus FE-210 Motherboard, Rear Casing: 5 단계, 이미지 1/1
    • Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
    • After removal of the screw the case will be loose, but do not tug it off. There is a cord connecting the rear controls to the motherboard.
  6. Removing Olympus FE-210 Motherboard: 6 단계, 이미지 1/3 Removing Olympus FE-210 Motherboard: 6 단계, 이미지 2/3 Removing Olympus FE-210 Motherboard: 6 단계, 이미지 3/3
    • Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
    • Lift the white latch using a fingernail or a spudger.
    • Pull the cord from its connector.
  7. Removing Olympus FE-210 Motherboard, LCD Screen: 7 단계, 이미지 1/2 Removing Olympus FE-210 Motherboard, LCD Screen: 7 단계, 이미지 2/2
    • Remove the two 2.7 mm screws using a #00 screwdriver.
    • After removing the screws the display will be free. Do not remove it. Like the rear case, there is a cord connecting it to the motherboard that must be disconnected first.
  8. Removing Olympus FE-210 Motherboard: 8 단계, 이미지 1/3 Removing Olympus FE-210 Motherboard: 8 단계, 이미지 2/3 Removing Olympus FE-210 Motherboard: 8 단계, 이미지 3/3
    • Using a spudger, lift the latch on the connector.
    • Remove the ribbon cord from its connector.
    • Remove the LCD from the rest of the camera.
  9. Removing Olympus FE-210 Motherboard, Motherboard: 9 단계, 이미지 1/2 Removing Olympus FE-210 Motherboard, Motherboard: 9 단계, 이미지 2/2
    • Remove the 2 pieces of translucent yellow tape.
    • Removing these pieces of tape will void the camera warranty. They serve no functional purpose and do not need to be replaced during reassembly.
  10. Removing Olympus FE-210 Motherboard: 10 단계, 이미지 1/2 Removing Olympus FE-210 Motherboard: 10 단계, 이미지 2/2
    • Remove the seven 2.7 mm using a #00 screwdriver.
  11. Removing Olympus FE-210 Motherboard: 11 단계, 이미지 1/1
    • Remove the ribbon cord located near the top right corner of the motherboard. Do this by carefully pulling the cord out of the socket using a pair of tweezers.
  12. Removing Olympus FE-210 Motherboard: 12 단계, 이미지 1/1
    • Disconnect the ribbon cord located on the left side of the motherboard.
    • Use tweezers or a spudger to lift the latch on the connector.
    • Carefully remove the cord from the connector.
  13. Removing Olympus FE-210 Motherboard: 13 단계, 이미지 1/2 Removing Olympus FE-210 Motherboard: 13 단계, 이미지 2/2
    • De-solder the 2 connection points.
    • Be careful to not damage any part of the circuit board with the soldering iron.
  14. Removing Olympus FE-210 Motherboard: 14 단계, 이미지 1/1
    • Remove the motherboard from the camera casing.
결론
Alex Wolff
회원 가입일: 01/21/11
234 평판
안내서 1개 작성함
Cal Poly, Team 4-36, Regan Winter 2011 Cal Poly, Team 4-36, Regan Winter 2011 회원
CPSU-REGAN-W11S4G36
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 3,852
