주요 콘텐츠로 건너뛰기
Removing Panasonic DVD-RV31 Player Motherboard
필요한 것
  1. Removing Panasonic DVD-RV31 Player Motherboard, Disk Tray Cover: 1 단계, 이미지 1/1
    • Eject the disk tray from the DVD player before removing power supply.
  2. Removing Panasonic DVD-RV31 Player Motherboard: 2 단계, 이미지 1/1
    • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier disassembly of the player.
  3. Removing Panasonic DVD-RV31 Player Motherboard, Outer Case: 3 단계, 이미지 1/2 Removing Panasonic DVD-RV31 Player Motherboard, Outer Case: 3 단계, 이미지 2/2
    • Remove the three screws running along the back edge of case cover.
    • Remove the two screws from each side of the case cover.
  4. Removing Panasonic DVD-RV31 Player Motherboard: 4 단계, 이미지 1/1
    • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
  5. Removing Panasonic DVD-RV31 Player Motherboard, Front Panel: 5 단계, 이미지 1/2 Removing Panasonic DVD-RV31 Player Motherboard, Front Panel: 5 단계, 이미지 2/2
    • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
  6. Removing Panasonic DVD-RV31 Player Motherboard, Motherboard: 6 단계, 이미지 1/2 Removing Panasonic DVD-RV31 Player Motherboard, Motherboard: 6 단계, 이미지 2/2
    • Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
    • Place forefinger under cable loop as shown, gripping with thumb.
    • Pull straight up. It should disconnect with little force.
  7. Removing Panasonic DVD-RV31 Player Motherboard: 7 단계, 이미지 1/2 Removing Panasonic DVD-RV31 Player Motherboard: 7 단계, 이미지 2/2
    • Using tweezers or pliers, squeeze the tabs of the plastic fasteners together. While doing this, gently lift up on the motherboard until the fasteners are released.
  8. Removing Panasonic DVD-RV31 Player Motherboard: 8 단계, 이미지 1/1
    • Remove the two screws securing the motherboard using a philips screw driver.
  9. Removing Panasonic DVD-RV31 Player Motherboard: 9 단계, 이미지 1/1
    • Lift the board from the side closest to the front panel (top of photo).
    • Gently apply force until bottom connector releases from power board below.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kevin
회원 가입일: 04/26/11
375 평판
안내서 8개 작성하였습니다
Cal Poly, Team 18-20, Garner Spring 2011 Cal Poly, Team 18-20, Garner Spring 2011 회원
CPSU-GARNER-S11S18G20
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,223
