주요 콘텐츠로 건너뛰기
Removing Philips DC320 37 Bottom Panel
필요한 것
  1. Removing Philips DC320 37 Bottom Panel, Docking entertainment system: 1 단계, 이미지 1/1
    • Pry off the four white feet with the pointed end of the spudger
  2. Removing Philips DC320 37 Bottom Panel: 2 단계, 이미지 1/1
    • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Removing Philips DC320 37 Bottom Panel: 3 단계, 이미지 1/1
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. Removing Philips DC320 37 Bottom Panel: 4 단계, 이미지 1/3 Removing Philips DC320 37 Bottom Panel: 4 단계, 이미지 2/3 Removing Philips DC320 37 Bottom Panel: 4 단계, 이미지 3/3
    • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Greg Lane
회원 가입일: 04/16/13
39 평판
안내서 4개 작성하였습니다
Cal Poly, Team 3-48, Amido Spring 2013 Cal Poly, Team 3-48, Amido Spring 2013 회원
CPSU-AMIDO-S13S3G48
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 16
전체 시간: 408
