주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Removing Playstation 2 Slimline SCPH-7500x Outer Shell
필요한 것
    • Turn off the PlayStation 2 (or PS2) and carefully unplug from the power source. Check to see there are no discs inside the console before flipping the game system upside-down.
  1. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 2 단계, 이미지 1/1
    • Locate the six feet on the bottom of the PS2.
    • Five of the feet are in plain sight and one of the feet is located under the black void sticker on the bottom of the device.
    • IMPORTANT: Removing the black VOID sticker will void the warranty of this device. Proceed at your own risk
    • Some versions of the console, such as the PAL Version, may not have this sticker. In this case, the foot or even the screw should be in plain sight.
  2. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 3 단계, 이미지 1/3 Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 3 단계, 이미지 2/3 Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 3 단계, 이미지 3/3
    • Use a spudger, flathead screwdriver, or fingernail to pry the five visible feet from the bottom of the device.
  3. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 4 단계, 이미지 1/2 Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 4 단계, 이미지 2/2
    • The sixth foot is located under the black VOID sticker. Remove the sticker before removing the foot underneath.
  4. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 5 단계, 이미지 1/2 Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 5 단계, 이미지 2/2
    • After all of the feet have been removed, locate the six 4.0mm screws on the base of the PS2.
  5. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 6 단계, 이미지 1/3 Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 6 단계, 이미지 2/3 Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 6 단계, 이미지 3/3
    • Use a #1 Phillips screwdriver to unscrew all six 4.0mm screws from the base of the PS2.
  6. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 7 단계, 이미지 1/3 Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 7 단계, 이미지 2/3 Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 7 단계, 이미지 3/3
    • Once all of the screws have been removed, pull apart the top plastic cover from the bottom plastic cover. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate. It will take force to pull apart the two halves.
  7. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 8 단계, 이미지 1/1
    • If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Jared Hirata
회원 가입일: 04/09/13
880 평판
안내서 7개 작성하였습니다
Cal Poly, Team 17-4, Regan Spring 2013 Cal Poly, Team 17-4, Regan Spring 2013 회원
CPSU-REGAN-S13S17G4
3 회원들
안내서 28개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 2,528
