주요 콘텐츠로 건너뛰기
Removing PowerMac G4 M5183 DVD-ROM Drive Tray
필요한 것
  1. Removing PowerMac G4 M5183 DVD-ROM Drive Tray, Opening PowerMac G4 M5183 Case: 1 단계, 이미지 1/2 Removing PowerMac G4 M5183 DVD-ROM Drive Tray, Opening PowerMac G4 M5183 Case: 1 단계, 이미지 2/2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Removing PowerMac G4 M5183 DVD-ROM Drive Tray, DVD-ROM Drive: 2 단계, 이미지 1/2 Removing PowerMac G4 M5183 DVD-ROM Drive Tray, DVD-ROM Drive: 2 단계, 이미지 2/2
    • Removing the faceplate.
    • On the inside of the case, find the two plastic tabs.
    • While depressing the tabs, remove the faceplate by pulling and rotating outward.
  3. Removing PowerMac G4 M5183 DVD-ROM Drive Tray: 3 단계, 이미지 1/1
    • Remove the two screws on the front of the drive with the Phillips #1 screwdriver.
  4. Removing PowerMac G4 M5183 DVD-ROM Drive Tray: 4 단계, 이미지 1/3 Removing PowerMac G4 M5183 DVD-ROM Drive Tray: 4 단계, 이미지 2/3 Removing PowerMac G4 M5183 DVD-ROM Drive Tray: 4 단계, 이미지 3/3
    • Pull the drive out to allow access to the power and ribbon cables. Do not fully remove.
    • Remove both the power and ribbon cable.
결승점
다른 26명이 해당 안내서를 완성하였습니다.
Justin Petrilli
회원 가입일: 01/21/10
3,096 평판
안내서 11개 작성하였습니다
Cal Poly, Team 13-24, Maness Winter 2010 Cal Poly, Team 13-24, Maness Winter 2010 회원
CPSU-MANESS-W10S13G24
4 회원들
안내서 25개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 37
전체 시간: 10,384
