주요 콘텐츠로 건너뛰기
Removing RAM from HP Elitebook 6930p
필요한 것
  1. Removing RAM from HP Elitebook 6930p, Battery Removal: 1 단계, 이미지 3개 중 1개 Removing RAM from HP Elitebook 6930p, Battery Removal: 1 단계, 이미지 3개 중 2개 Removing RAM from HP Elitebook 6930p, Battery Removal: 1 단계, 이미지 3개 중 3개
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing RAM from HP Elitebook 6930p, Keyboard: 2 단계, 이미지 3개 중 1개 Removing RAM from HP Elitebook 6930p, Keyboard: 2 단계, 이미지 3개 중 2개 Removing RAM from HP Elitebook 6930p, Keyboard: 2 단계, 이미지 3개 중 3개
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing RAM from HP Elitebook 6930p: 3 단계, 이미지 3개 중 1개 Removing RAM from HP Elitebook 6930p: 3 단계, 이미지 3개 중 2개 Removing RAM from HP Elitebook 6930p: 3 단계, 이미지 3개 중 3개
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing RAM from HP Elitebook 6930p: 4 단계, 이미지 3개 중 1개 Removing RAM from HP Elitebook 6930p: 4 단계, 이미지 3개 중 2개 Removing RAM from HP Elitebook 6930p: 4 단계, 이미지 3개 중 3개
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  5. Removing RAM from HP Elitebook 6930p, RAM: 5 단계, 이미지 2개 중 1개 Removing RAM from HP Elitebook 6930p, RAM: 5 단계, 이미지 2개 중 2개
    • Locate RAM module
    • Push metal tabs outwards away from the RAM module to release it.
    • The RAM module will spring up and can be removed from the RAM slot.
결론
다른 22명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Richdave
회원 가입일: 04/09/10
32,729 평판
안내서 30개를 작성함
Master Techs Master Techs 회원
Community
329 회원들
안내서 1,452개를 작성함
7가이드 댓글
HP Elitebook 6930p. Huh !!!!
Desingn constructor is the largest manufacturer idiot. Put one memory slot inside, located under the keyboard denotes an unparalleled stupidity.
astorp2000 - 답글
I agree with above comment, weird thing to do.
S Cleaver - 답글
Thanks for your splendid guide. I don't have a plastic pry tool. A bass guitar plectrum works just as well though. The whole job took under 10 mins to complete. I now have X2, 2GB memory cards installed. This is plenty to run Manjaro JWM 16,04.1. It boots up only using 180 MB of RAM - perfect.
Andy Mitchell - 답글
Great guide. Trying to part out computer and couldn't figure out where other memory slot located. Agree dumb place for it.
Been Allison - 답글
the ram is acessible through the door in the middle, need to unscrew 2 screws LOL
Lukasz Nowakowski - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 62
전체 시간: 31,673
