부품
No parts specified.
  1. Open the tray by pressing the eject button Remove the DVD tray faceplate by pushing the faceplate up off of the tray. Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
    • Open the tray by pressing the eject button
    • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  2. Press the eject button to insert the tray
    • Press the eject button to insert the tray
    • After the tray is closed unplug DVD player
  3. Unscrew the 3 screws in the back.
    • Unscrew the 3 screws in the back.
  4. Pull the outer case upward and then towards you. Pull the outer case upward and then towards you.
    • Pull the outer case upward and then towards you.
  5. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate.
    • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
  6. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  7. Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously. Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
    • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
  8. Locate the white clip that attaches the cord to the motherboard Grasp clip and squeeze to release Lift up and remove power cord
    • Locate the white clip that attaches the cord to the motherboard
    • Grasp clip and squeeze to release
    • Lift up and remove power cord
    • Slide cord mount from outer case
  9. Remove the three screws holding in the DVD tray Remove the three screws holding in the DVD tray Remove the three screws holding in the DVD tray
    • Remove the three screws holding in the DVD tray
  10. Remove the power cord and first two ribbons by pulling them directly out of their sockets. Remove the power cord and first two ribbons by pulling them directly out of their sockets.
    • Remove the power cord and first two ribbons by pulling them directly out of their sockets.
  11. Gently lift the DVD tray off of the motherboard. Gently lift the DVD tray off of the motherboard.
    • Gently lift the DVD tray off of the motherboard.
  12. Unscrew the 2 screws on the motherboard Unscrew the 2 screws on the back
    • Unscrew the 2 screws on the motherboard
    • Unscrew the 2 screws on the back
  13. Disconnect the wires and ribbon by pulling them out of their respective connections Disconnect the wires and ribbon by pulling them out of their respective connections Disconnect the wires and ribbon by pulling them out of their respective connections
    • Disconnect the wires and ribbon by pulling them out of their respective connections
  14. Lift board up and out of the lower case Lift board up and out of the lower case
    • Lift board up and out of the lower case
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mitchell Hart
회원 가입일: 2011년 01월 21일
834 평판
안내서 5개 작성하였습니다
Cal Poly, Team 3-30, Regan Winter 2011 Cal Poly, Team 3-30, Regan Winter 2011 회원
CPSU-REGAN-W11S3G30
4 회원들
안내서 8개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 2,941
