주요 콘텐츠로 건너뛰기
Removing Samsung DVD-P230 Tray
필요한 것
  1. Removing Samsung DVD-P230 Tray, Outer Cover & Faceplate: 1 단계, 이미지 1/3 Removing Samsung DVD-P230 Tray, Outer Cover & Faceplate: 1 단계, 이미지 2/3 Removing Samsung DVD-P230 Tray, Outer Cover & Faceplate: 1 단계, 이미지 3/3
    • Open the tray by pressing the eject button
    • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  2. Removing Samsung DVD-P230 Tray: 2 단계, 이미지 1/1
    • Press the eject button to insert the tray
    • After the tray is closed unplug DVD player
  3. Removing Samsung DVD-P230 Tray: 3 단계, 이미지 1/1
    • Unscrew the 3 screws in the back.
  4. Removing Samsung DVD-P230 Tray: 4 단계, 이미지 1/2 Removing Samsung DVD-P230 Tray: 4 단계, 이미지 2/2
    • Pull the outer case upward and then towards you.
  5. Removing Samsung DVD-P230 Tray: 5 단계, 이미지 1/3 Removing Samsung DVD-P230 Tray: 5 단계, 이미지 2/3 Removing Samsung DVD-P230 Tray: 5 단계, 이미지 3/3
    • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
  6. Removing Samsung DVD-P230 Tray: 6 단계, 이미지 1/2 Removing Samsung DVD-P230 Tray: 6 단계, 이미지 2/2
    • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
  7. Removing Samsung DVD-P230 Tray, Power Cord: 7 단계, 이미지 1/3 Removing Samsung DVD-P230 Tray, Power Cord: 7 단계, 이미지 2/3 Removing Samsung DVD-P230 Tray, Power Cord: 7 단계, 이미지 3/3
    • Locate the white clip that attaches the cord to the motherboard
    • Grasp clip and squeeze to release
    • Lift up and remove power cord
    • Slide cord mount from outer case
  8. Removing Samsung DVD-P230 Tray, Tray: 8 단계, 이미지 1/3 Removing Samsung DVD-P230 Tray, Tray: 8 단계, 이미지 2/3 Removing Samsung DVD-P230 Tray, Tray: 8 단계, 이미지 3/3
    • Remove the three screws holding in the DVD tray
  9. Removing Samsung DVD-P230 Tray: 9 단계, 이미지 1/2 Removing Samsung DVD-P230 Tray: 9 단계, 이미지 2/2
    • Remove the power cord and first two ribbons by pulling them directly out of their sockets.
  10. Removing Samsung DVD-P230 Tray: 10 단계, 이미지 1/2 Removing Samsung DVD-P230 Tray: 10 단계, 이미지 2/2
    • Gently lift the DVD tray off of the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Evan Domingue
회원 가입일: 01/28/11
410 평판
안내서 3개 작성하였습니다
Cal Poly, Team 3-30, Regan Winter 2011 Cal Poly, Team 3-30, Regan Winter 2011 회원
CPSU-REGAN-W11S3G30
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 6
전체 시간: 1,937
