주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Removing Samsung ML2510 Back Panel
필요한 것
  1. Removing Samsung ML2510 Back Panel, Removing Samsung ML2510 Back Panel: 1 단계, 이미지 1/3 Removing Samsung ML2510 Back Panel, Removing Samsung ML2510 Back Panel: 1 단계, 이미지 2/3 Removing Samsung ML2510 Back Panel, Removing Samsung ML2510 Back Panel: 1 단계, 이미지 3/3
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Removing Samsung ML2510 Back Panel: 2 단계, 이미지 1/1
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Removing Samsung ML2510 Back Panel: 3 단계, 이미지 1/3 Removing Samsung ML2510 Back Panel: 3 단계, 이미지 2/3 Removing Samsung ML2510 Back Panel: 3 단계, 이미지 3/3
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
결론
다른 4명이 해당 안내서를 완성하였습니다.
bbaustin
회원 가입일: 10/12/11
268 평판
안내서 6개 작성하였습니다
Cal Poly, Team 17-18, Regan Fall 2011 Cal Poly, Team 17-18, Regan Fall 2011 회원
CPSU-REGAN-F11S17G18
4 회원들
안내서 12개 작성하였습니다
댓글 3개
Very easy to follow. I think I would have broken something if I had not followed these simple steps.
rob - 답글
Thank you on how to do this. A little force is required to lift the top cover edges one by one to get the back cover off, but it does come off, without taking the top cover off. I think my solenoid is bad, as the printer takes two sheets of paper initially and then more right afterwards. The rubber pick up wheel seems to be fine after cleaning, as it picks up the paper without issue, just multiple sheets is all.
kirkdcharles - 답글
Thanks. I would have broken the top cover or back panel if I did not read your post. It take a little force to pull the back cover off while applying upward pressure to the top cover ends, one at a time. I think I have to replace the solenoid as the rubber pick up wheel pulls the paper up fine, but multiple sheets after the first rotation of the wheel.
kirkdcharles - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 20
전체 시간: 6,123
