부품
부품은 필요하지 않습니다.
  1. Place the plastic opening tool in the bottom corner of the phone in the crevice between the flap to remove flip  the cover.
    • Place the plastic opening tool in the bottom corner of the phone in the crevice between the flap to remove flip the cover.
  2. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  3. Remove the cover with  a slight twisting motion. This is what the phone will look like after the cover is removed.
    • Remove the cover with a slight twisting motion. This is what the phone will look like after the cover is removed.
  4. To replace the flip cover, repeat removal steps in the opposite order; be sure to connect the new cover by matching the square side of the cover to the square side of the phone base and the circle side of the cover to the circle side of the phone base. To replace the flip cover, repeat removal steps in the opposite order; be sure to connect the new cover by matching the square side of the cover to the square side of the phone base and the circle side of the cover to the circle side of the phone base.
    • To replace the flip cover, repeat removal steps in the opposite order; be sure to connect the new cover by matching the square side of the cover to the square side of the phone base and the circle side of the cover to the circle side of the phone base.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
manning
회원 가입일: 2012년 03월 12일
21 평판
안내서 1개 작성함
Clemson, Team 1-4, Benson Spring 2012 Clemson, Team 1-4, Benson Spring 2012 회원
CLEM-BENSON-S12S1G4
4 회원들
안내서 14개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 1,623
