주요 콘텐츠로 건너뛰기
Removing Texas Instruments TI-92 Back Cover
  1. Removing Texas Instruments TI-92 Back Cover, Back Cover: 1 단계, 이미지 1/3 Removing Texas Instruments TI-92 Back Cover, Back Cover: 1 단계, 이미지 2/3 Removing Texas Instruments TI-92 Back Cover, Back Cover: 1 단계, 이미지 3/3
    • The first step to any repair operation is to remove the front cover.
    • Grab the back of the calculator with one hand and the cover with the other.
    • Pull the cover off from one of the sides for easy removal.
  2. Removing Texas Instruments TI-92 Back Cover: 2 단계, 이미지 1/2 Removing Texas Instruments TI-92 Back Cover: 2 단계, 이미지 2/2
    • Orientate the calculator with the top facing towards you.
    • Slide the locking tab,found on the top part of the calculator, to the unlock position.
  3. Removing Texas Instruments TI-92 Back Cover: 3 단계, 이미지 1/2 Removing Texas Instruments TI-92 Back Cover: 3 단계, 이미지 2/2
    • "Locking Tab"
    • To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
    • Then with the front of the calculator facing down, pull up on the back cover.
    • The calculator should now be orientated with the front facing down, as shown in picture 2.
결론
Daniel Maldonado
회원 가입일: 04/14/10
240 평판
안내서 9개 작성하였습니다
Cal Poly, Team 15-51, Garner Spring 2010 Cal Poly, Team 15-51, Garner Spring 2010 회원
CPSU-GARNER-S10S15G51
5 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 17
전체 시간: 3,290
