주요 콘텐츠로 건너뛰기
Removing and Cleaning Dishwasher Spray Arm
필요한 것
  1. Removing and Cleaning Dishwasher Spray Arm, Removing and Cleaning Dishwasher Spray Arm: 1 단계, 이미지 1/1
    • Open the dishwasher door to access the interior and locate the dishwasher spray arm
  2. Removing and Cleaning Dishwasher Spray Arm: 2 단계, 이미지 1/1
    • Remove the spray arm by grabbing the edge and slowly lifting it up with a bit of force.
  3. Removing and Cleaning Dishwasher Spray Arm: 3 단계, 이미지 1/2 Removing and Cleaning Dishwasher Spray Arm: 3 단계, 이미지 2/2
    • Place the spray arm and soak it in a big bowl of warm, soapy water to help loosen any debris on the spray arm.
  4. Removing and Cleaning Dishwasher Spray Arm: 4 단계, 이미지 1/3 Removing and Cleaning Dishwasher Spray Arm: 4 단계, 이미지 2/3 Removing and Cleaning Dishwasher Spray Arm: 4 단계, 이미지 3/3
    • Equip your toothbrush (soft brush is fine too) and clean around the edges and nozzles to get out any dirt or debris.
  5. Removing and Cleaning Dishwasher Spray Arm: 5 단계, 이미지 1/3 Removing and Cleaning Dishwasher Spray Arm: 5 단계, 이미지 2/3 Removing and Cleaning Dishwasher Spray Arm: 5 단계, 이미지 3/3
    • Take out your spray arm, use any type of clean water source (e.g your sink) and rinse the spray arm thoroughly with warm water.
  6. Removing and Cleaning Dishwasher Spray Arm: 6 단계, 이미지 1/3 Removing and Cleaning Dishwasher Spray Arm: 6 단계, 이미지 2/3 Removing and Cleaning Dishwasher Spray Arm: 6 단계, 이미지 3/3
    • Equip your dishcloth and start drying around the edges and nozzles.
  7. Removing and Cleaning Dishwasher Spray Arm: 7 단계, 이미지 1/3 Removing and Cleaning Dishwasher Spray Arm: 7 단계, 이미지 2/3 Removing and Cleaning Dishwasher Spray Arm: 7 단계, 이미지 3/3
    • Take your spray arm and place it back in its original compartment. Do this by grabbing the edge and slowly pushing down with a bit of force.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Timileyin Adeoye
회원 가입일: 09/14/23
175 평판
안내서 1개 작성함
York University, Team A-1, O'Regan Fall 2023 York University, Team A-1, O'Regan Fall 2023 회원
YORK-O'REGAN-F23SAG1
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 38
전체 시간: 286
