주요 콘텐츠로 건너뛰기
Removing the Anti-Glare Coating from a MacBook Pro Screen
필요한 것
  1. Removing the Anti-Glare Coating from a MacBook Pro Screen, Removing the Anti-Glare Coating from a MacBook Pro Screen: 1 단계, 이미지 2개 중 1개 Removing the Anti-Glare Coating from a MacBook Pro Screen, Removing the Anti-Glare Coating from a MacBook Pro Screen: 1 단계, 이미지 2개 중 2개
    • Power off the MacBook by clicking on the Apple logo in the top left corner of the screen. Then, scroll down the list and click "Shut Down."
    • Disconnect any attached cables such as chargers or wired headphones.
    • Disconnecting cables before beginning this repair is crucial to avoid moisture damage and electrical shocks. Cables should not be present in order to fully clean the ports and connectors.
  2. Removing the Anti-Glare Coating from a MacBook Pro Screen: 2 단계, 이미지 2개 중 1개 Removing the Anti-Glare Coating from a MacBook Pro Screen: 2 단계, 이미지 2개 중 2개
    • Gently wipe the screen's surface with either a microfiber cloth or cotton pad to remove any residual dust or oil.
  3. Removing the Anti-Glare Coating from a MacBook Pro Screen: 3 단계, 이미지 1개 중 1개
    • Apply a mild plastic polish or cleaning solution like Bar Keeper’s Friend (liquid) to a cotton pad.
  4. Removing the Anti-Glare Coating from a MacBook Pro Screen: 4 단계, 이미지 2개 중 1개 Removing the Anti-Glare Coating from a MacBook Pro Screen: 4 단계, 이미지 2개 중 2개
    • Softly rub the coating from the cotton pad onto the MacBook's screen in small circular motions.
    • Be careful not to damage the screen underneath.
  5. Removing the Anti-Glare Coating from a MacBook Pro Screen: 5 단계, 이미지 1개 중 1개
    • Wipe the screen clean with a new microfiber cloth or cotton pad. Inspect for remaining coating.
    • If the damaged anti-glare coating still remains, repeat this process as many times as needed.
결승점
작성자
2다른 기여자 명과 함께
Nicole Vo
회원 가입일: 05/12/25
121 평판
안내서 1개를 작성함
UC Davis, Team 1-4, Whithaus Spring 2025 UC Davis, Team 1-4, Whithaus Spring 2025 회원
UCD-WHITHAUS-S25S1G4
3 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 23
지난 30일: 116
전체 시간: 468
