소개
This guide will explain how to remove the display hinge. The tools required for this section are the spudger and the PH 2 screwdriver.
도구
부품
지정된 부품이 없습니다.
Flip the Cinema Display so it is on its face and the feet are pointed away from you.
Using the PH 2 screwdriver, unscrew the three feet screws (9.52 x 4.43 mm).
Remove the back foot from the hinge mount by gently pulling it upwards.
다른 3명이 해당 안내서를 완성하였습니다.
