소개
This guide will focus on removing the back cover of the upper part of the phone. This will allow the user to access many of the other parts of the phone, including the motherboard, the keypad, the antenna, and the speaker.
부품
부품은 필요하지 않습니다.
  1. Orient the phone so that the phone model and other descriptive information is facing upward. Locate the two silver screws near the hinge where the battery is housed.
    • Orient the phone so that the phone model and other descriptive information is facing upward.
    • Locate the two silver screws near the hinge where the battery is housed.
    • Remove the silver screws using a Phillips head #2 screwdriver.
  2. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  3. Pull off the back panel of the phone. Make sure you pull the cover off carefully in order to prevent damage to the back cover. Make sure you pull the cover off carefully in order to prevent damage to the back cover.
    • Pull off the back panel of the phone.
    • Make sure you pull the cover off carefully in order to prevent damage to the back cover.
결론
Elizabeth Kelly
회원 가입일: 2012년 10월 22일
501 평판
안내서 5개 작성하였습니다
Clemson, Team 15-1, Benson Fall 2012 Clemson, Team 15-1, Benson Fall 2012 회원
CLEM-BENSON-F12S15G1
4 회원들
안내서 10개 작성하였습니다
Help I am still struggling to get the back cover off
caroline williams - 답글
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 48
전체 시간: 1,396
