주요 콘텐츠로 건너뛰기
Removing the Back Panel of the Phone
필요한 것
  1. Removing the Back Panel of the Phone, Removing the Back Panel: 1 단계, 이미지 1/2 Removing the Back Panel of the Phone, Removing the Back Panel: 1 단계, 이미지 2/2
    • Orient the phone so that the phone model and other descriptive information is facing upward.
    • Locate the two silver screws near the hinge where the battery is housed.
    • Remove the silver screws using a Phillips head #2 screwdriver.
  2. Removing the Back Panel of the Phone: 2 단계, 이미지 1/3 Removing the Back Panel of the Phone: 2 단계, 이미지 2/3 Removing the Back Panel of the Phone: 2 단계, 이미지 3/3
    • Pull off the back panel of the phone.
    • Make sure you pull the cover off carefully in order to prevent damage to the back cover.
결론
Elizabeth Kelly
회원 가입일: 10/22/12
501 평판
안내서 5개 작성하였습니다
Clemson, Team 15-1, Benson Fall 2012 Clemson, Team 15-1, Benson Fall 2012 회원
CLEM-BENSON-F12S15G1
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
Help I am still struggling to get the back cover off
caroline williams - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 65
전체 시간: 4,496
