주요 콘텐츠로 건너뛰기
Removing the Behringer Eurolive B212D Electronics Box
필요한 것
  1. Removing the Behringer Eurolive B212D Electronics Box, Removing the Behringer Eurolive B212D Electronics Box: 1 단계, 이미지 1/1
    • CAUTION: Unplug your speaker from the power outlet.
    • Remove the 8 Phillips screws from the back of the speaker.
    Eurolive B212d back plate requirement
    Ashok Ahlawat - 답글
  2. Removing the Behringer Eurolive B212D Electronics Box: 2 단계, 이미지 1/1
    • Carefully remove the back panel, lifting out the metal electronics-box with it.
    • To avoid damaging your speaker, remove slowly, as there is still a wire attached from the electronics box to the speaker.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Troy W. Weber
회원 가입일: 03/29/12
1,431 평판
안내서 6개 작성하였습니다
댓글 2개
I want to buy the hole back panel, but I don't where?, tell me
miguelangelvera63 - 답글
I will wait for answer
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 14
전체 시간: 3,529
