메인 콘텐츠로 스킵하기
부품
지정된 부품이 없습니다.
  1. Remove the back two 14.0 mm Torx #10 screws.
    • Remove the back two 14.0 mm Torx #10 screws.
  2. Lay the printer on its back.
    • Lay the printer on its back.
    • Grab the paper tray by its right side and pull it to the left and up.
  3. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  4. Open the frontal access panel by lifting it from the top.
    • Open the frontal access panel by lifting it from the top.
    • Similar to the paper tray, grab it from the right side and pull it to the left and up.
  5. Take out the two frontal 14.0 mm Torx #10 screws. Carefully lift the frontal cover. Don't lift it up aggressively. A strip will be attached to it.
    • Take out the two frontal 14.0 mm Torx #10 screws.
    • Carefully lift the frontal cover.
    • Don't lift it up aggressively. A strip will be attached to it.
결론
Justin Taiki Fukada
회원 가입일: 2014년 01월 25일
822 평판
안내서 7개 작성하였습니다
Cal Poly, Team 1-41, Maness Winter 2014 Cal Poly, Team 1-41, Maness Winter 2014 회원
CPSU-MANESS-W14S1G41
4 회원들
안내서 7개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 22
