주요 콘텐츠로 건너뛰기
Logitech Webcam Pro 9000 Front and Back Cover Replacement
필요한 것
  1. Logitech Webcam Pro 9000 Front and Back Cover Replacement, Front and Back Cover: 1 단계, 이미지 1/2 Logitech Webcam Pro 9000 Front and Back Cover Replacement, Front and Back Cover: 1 단계, 이미지 2/2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Logitech Webcam Pro 9000 Front and Back Cover Replacement: 2 단계, 이미지 1/2 Logitech Webcam Pro 9000 Front and Back Cover Replacement: 2 단계, 이미지 2/2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
결론
Timothy Forrest
회원 가입일: 04/18/13
19 평판
안내서 2개 작성하였습니다
Cal Poly, Team 12-34, Amido Spring 2013 Cal Poly, Team 12-34, Amido Spring 2013 회원
CPSU-AMIDO-S13S12G34
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 19
전체 시간: 1,252
