주요 콘텐츠로 건너뛰기
Removing the Dell Inspiron 1150 Keyboard
필요한 것
  1. Removing the Dell Inspiron 1150 Keyboard, Removing Dell Inspiron 1150 Battery: 1 단계, 이미지 1/3 Removing the Dell Inspiron 1150 Keyboard, Removing Dell Inspiron 1150 Battery: 1 단계, 이미지 2/3 Removing the Dell Inspiron 1150 Keyboard, Removing Dell Inspiron 1150 Battery: 1 단계, 이미지 3/3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing the Dell Inspiron 1150 Keyboard, Keyboard: 2 단계, 이미지 1/3 Removing the Dell Inspiron 1150 Keyboard, Keyboard: 2 단계, 이미지 2/3 Removing the Dell Inspiron 1150 Keyboard, Keyboard: 2 단계, 이미지 3/3
    • Use a spudger to lift the notched right edge of the hinge cover, and pry it loose
    • You need to lay the LCD screen down flat to allow the hinge cover to be lifted off
    • Lift the hinge cover off and set aside
  3. Removing the Dell Inspiron 1150 Keyboard: 3 단계, 이미지 1/3 Removing the Dell Inspiron 1150 Keyboard: 3 단계, 이미지 2/3 Removing the Dell Inspiron 1150 Keyboard: 3 단계, 이미지 3/3
    • Remove 4ea M2 x 3mm keyboard screws
    • Lift up keyboard from the rear to expose the connector below
    • Disconnect the keyboard ribbon cable from the mother board
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Richdave
회원 가입일: 04/09/10
32,081 평판
안내서 30개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,539개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 10
전체 시간: 873
