필요한 것
All you need is in the Pro Tool Kit from iFixit.com
First you pop off the silver retainer around the whole gps system. The retainer is snapped on in various spots all around the retainer. Just work your way around till you pop all the snaps and it will come right off. Take not of the hole you see on the left part of the screen on the retainer to put back on the right way.
Take metal backing off of lcd screen.
There are 2 ribbon cables coming from the screen. The one on the left is for the screen and the one on the right is the digitizer.
To reassemble your device, follow these instructions in reverse order. When ordering a new screen make sure you get a lcd screen with digitizer. It will make it alot easeir down the road. I got on ebay and found a lcd screen with digitizer for $20.00 from a guy in china.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 3개
Nuvi 1300 requires a T5 - NOT, repeat NOT, a T6.
I followed the instruction and easily replaced scratced screen. Thanks a lot.
I actualy did.it before i
