주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
  1. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Turn off your computer and remove the power cable by pulling it straight out of its socket.
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the two Phillips #2 screws that secure the case door to the device. Remove the two Phillips #2 screws that secure the case door to the device.
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the side case door by pushing towards the rear of the device with your hand. This may take considerable force so keep pushing! Once you slide the door back, remove it by pulling it outwards from the device.
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the side case door by pushing towards the rear of the device with your hand. Once again, this may take considerable force. Once you slide the door back, remove it by pulling it outwards from the device.
    • Once again, this may take considerable force.
결승점
다른 5명이 해당 안내서를 완성하였습니다.
Logan Pace
회원 가입일: 2011년 10월 12일
2,146 평판
안내서 9개 작성하였습니다
Cal Poly, Team 17-16, Regan Fall 2011 Cal Poly, Team 17-16, Regan Fall 2011 회원
CPSU-REGAN-F11S17G16
4 회원들
안내서 17개 작성하였습니다
Good , trying an apps
Nur Izzatie - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 1,646
