주요 콘텐츠로 건너뛰기
Removing the HP Compaq dx2000MT Optical (CD) Drive
필요한 것
  1. Removing the HP Compaq dx2000MT Optical (CD) Drive, Removing the HP Compaq dx2000MT Case Doors: 1 단계, 이미지 1/1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Removing the HP Compaq dx2000MT Optical (CD) Drive: 2 단계, 이미지 1/2 Removing the HP Compaq dx2000MT Optical (CD) Drive: 2 단계, 이미지 2/2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Removing the HP Compaq dx2000MT Optical (CD) Drive: 3 단계, 이미지 1/3 Removing the HP Compaq dx2000MT Optical (CD) Drive: 3 단계, 이미지 2/3 Removing the HP Compaq dx2000MT Optical (CD) Drive: 3 단계, 이미지 3/3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Removing the HP Compaq dx2000MT Optical (CD) Drive: 4 단계, 이미지 1/3 Removing the HP Compaq dx2000MT Optical (CD) Drive: 4 단계, 이미지 2/3 Removing the HP Compaq dx2000MT Optical (CD) Drive: 4 단계, 이미지 3/3
    • Once again, this may take considerable force.
  5. Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: 5 단계, 이미지 1/3 Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: 5 단계, 이미지 2/3 Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: 5 단계, 이미지 3/3
    • Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive.
  6. Removing the HP Compaq dx2000MT Optical (CD) Drive: 6 단계, 이미지 1/2 Removing the HP Compaq dx2000MT Optical (CD) Drive: 6 단계, 이미지 2/2
    • Remove the 2 Torx T15 screws holding the optical drive in place.
  7. Removing the HP Compaq dx2000MT Optical (CD) Drive: 7 단계, 이미지 1/2 Removing the HP Compaq dx2000MT Optical (CD) Drive: 7 단계, 이미지 2/2
    • Remove the other 2 Torx T15 screws holding the other side of the drive in place.
  8. Removing the HP Compaq dx2000MT Optical (CD) Drive: 8 단계, 이미지 1/3 Removing the HP Compaq dx2000MT Optical (CD) Drive: 8 단계, 이미지 2/3 Removing the HP Compaq dx2000MT Optical (CD) Drive: 8 단계, 이미지 3/3
    • Remove the optical drive by sliding it out the front of the device.
결론
Logan Pace
회원 가입일: 10/12/11
2,224 평판
안내서 9개 작성하였습니다
Cal Poly, Team 17-16, Regan Fall 2011 Cal Poly, Team 17-16, Regan Fall 2011 회원
CPSU-REGAN-F11S17G16
4 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,467
