이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn off your computer and remove the power cable by pulling it straight out of its socket.
Remove the two Phillips #2 screws that secure the case door to the device.
Remove the side case door by pushing towards the rear of the device with your hand.
Once you slide the door back, remove it by pulling it outwards from the device.
Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive.
Remove the other 2 Torx T15 screws holding the other side of the drive in place.
