소개
This guide will show you how to locate and remove the Bluetooth module
도구
부품
부품은 필요하지 않습니다.
Flip laptop over and locate the battery release button
Push release button to the left to release battery and gently pull battery from the laptop
Locate the Bluetooth module cover on the bottom of the laptop
Loosen the M2.0×5.0 captive screw and remove the cover by by lifting it straight up
Gently lift the Bluetooth module up and over the retaining clip. A plastic spudger may be useful.
Disconnect the connector being careful not to damage the fine wires on the cable.
다른 3명이 해당 안내서를 완성하였습니다.
