주요 콘텐츠로 건너뛰기
Removing the HP Elitebook 6930p Hard Drive
필요한 것
  1. Removing the HP Elitebook 6930p Hard Drive, Battery Removal: 1 단계, 이미지 1/3 Removing the HP Elitebook 6930p Hard Drive, Battery Removal: 1 단계, 이미지 2/3 Removing the HP Elitebook 6930p Hard Drive, Battery Removal: 1 단계, 이미지 3/3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p Hard Drive, Hard Drive: 2 단계, 이미지 1/3 Removing the HP Elitebook 6930p Hard Drive, Hard Drive: 2 단계, 이미지 2/3 Removing the HP Elitebook 6930p Hard Drive, Hard Drive: 2 단계, 이미지 3/3
    • With the bottom of the laptop facing up and the front toward you locate and loosen the two M2.0×5.0 captive screws holding the hard drive bay cover closed.
    • Lift the left side of the bay cover and swing it up and to the right to remove it.
    • Loosen the M2.5×10.0 captive screw that holds the hard drive in.
    • Grasp the plastic tab and slide the hard drive to the right to disconnect it from the motherboard.
    • Lift the hard drive straight up and out of the laptop.
  3. Removing the HP Elitebook 6930p Hard Drive: 3 단계, 이미지 1/2 Removing the HP Elitebook 6930p Hard Drive: 3 단계, 이미지 2/2
    • To remove the hard drive from the bracket remove the two M3.0×4.0 screws from each side of the hard drive.
결론
다른 17명이 해당 안내서를 완성하였습니다.
Richdave
회원 가입일: 04/09/10
32,177 평판
안내서 30개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,468개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 30
전체 시간: 9,692
