주요 콘텐츠로 건너뛰기
Removing the HP Elitebook 6930p Keyboard
필요한 것
  1. Removing the HP Elitebook 6930p Keyboard, Battery Removal: 1 단계, 이미지 1/3 Removing the HP Elitebook 6930p Keyboard, Battery Removal: 1 단계, 이미지 2/3 Removing the HP Elitebook 6930p Keyboard, Battery Removal: 1 단계, 이미지 3/3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p Keyboard, Keyboard: 2 단계, 이미지 1/3 Removing the HP Elitebook 6930p Keyboard, Keyboard: 2 단계, 이미지 2/3 Removing the HP Elitebook 6930p Keyboard, Keyboard: 2 단계, 이미지 3/3
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing the HP Elitebook 6930p Keyboard: 3 단계, 이미지 1/3 Removing the HP Elitebook 6930p Keyboard: 3 단계, 이미지 2/3 Removing the HP Elitebook 6930p Keyboard: 3 단계, 이미지 3/3
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
    After loosening the four moveable tabs at the screen end you simply pull slightly to the right to loosen the left side and then up to loose the five tabs in the lower end, then flip keyboard over so keys face the screen.
    e5frog - 답글
  4. Removing the HP Elitebook 6930p Keyboard: 4 단계, 이미지 1/3 Removing the HP Elitebook 6930p Keyboard: 4 단계, 이미지 2/3 Removing the HP Elitebook 6930p Keyboard: 4 단계, 이미지 3/3
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
    There is no need at all to loosen any ribbon cables, after flipping keyboard so it faces keys against screen you can simply remove the RAM. Don't fiddle with the ribbon cables.
    e5frog - 답글
    Unless, of course, that your actually replacing the keyboard! In which case, remember to keep that rubber pointing device for replacing the one that you’ll probably eventually lose.
    Dennis - 답글
결론
다른 9명이 해당 안내서를 완성하였습니다.
Richdave
회원 가입일: 04/09/10
32,063 평판
안내서 30개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,528개 작성하였습니다
댓글 2개
Look easy to remove !! I have a hp elitebook 6930p it need a new keyboard but it hard for me to find one for my elitebook 6930p online they look the same but none of them have the part number i need ! Could i use any hp elitebook 6930p replacement keyboard or were can i find the right keyboard number on the elitebook 6930 i just might be looking at the wrote number ! Need help !!
Daisy - 답글
CHICONY
MP-06803U46930 MP-06803US6442
DARFON
9J.N8282.K01 NSK-H4K01
HP COMPAQ
483010-001 90.4V907.S01 9J.N8282.K01 BAHHH3AM2WS0E7
MP-06803U46930 MP-06803US6442 NSK-H4K01 V070530CS1
any of these should work
Keegan -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 10,520
