주요 콘텐츠로 건너뛰기
Removing the HP Elitebook 6930p Switch Cover
필요한 것
  1. Removing the HP Elitebook 6930p Switch Cover, Battery Removal: 1 단계, 이미지 3개 중 1개 Removing the HP Elitebook 6930p Switch Cover, Battery Removal: 1 단계, 이미지 3개 중 2개 Removing the HP Elitebook 6930p Switch Cover, Battery Removal: 1 단계, 이미지 3개 중 3개
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p Switch Cover, Keyboard: 2 단계, 이미지 3개 중 1개 Removing the HP Elitebook 6930p Switch Cover, Keyboard: 2 단계, 이미지 3개 중 2개 Removing the HP Elitebook 6930p Switch Cover, Keyboard: 2 단계, 이미지 3개 중 3개
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing the HP Elitebook 6930p Switch Cover: 3 단계, 이미지 3개 중 1개 Removing the HP Elitebook 6930p Switch Cover: 3 단계, 이미지 3개 중 2개 Removing the HP Elitebook 6930p Switch Cover: 3 단계, 이미지 3개 중 3개
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing the HP Elitebook 6930p Switch Cover: 4 단계, 이미지 3개 중 1개 Removing the HP Elitebook 6930p Switch Cover: 4 단계, 이미지 3개 중 2개 Removing the HP Elitebook 6930p Switch Cover: 4 단계, 이미지 3개 중 3개
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  5. Removing the HP Elitebook 6930p Switch Cover, Switch Cover: 5 단계, 이미지 3개 중 1개 Removing the HP Elitebook 6930p Switch Cover, Switch Cover: 5 단계, 이미지 3개 중 2개 Removing the HP Elitebook 6930p Switch Cover, Switch Cover: 5 단계, 이미지 3개 중 3개
    • Remove the two M2.0×4.0 broad-head screws.
    • Remove the three Torx T8 M2.5×7.0 screws.
  6. Removing the HP Elitebook 6930p Switch Cover: 6 단계, 이미지 3개 중 1개 Removing the HP Elitebook 6930p Switch Cover: 6 단계, 이미지 3개 중 2개 Removing the HP Elitebook 6930p Switch Cover: 6 단계, 이미지 3개 중 3개
    • Turn the computer over with the front toward you and the open the computer as far as possible.
    • Release the ZIF connector for the power button board cable.
    • Remove the switch cover by lifting it straight up and flip it forward.
    • Release the ZIF connector for the LED board cable.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Richdave
회원 가입일: 04/09/10
32,729 평판
안내서 30개를 작성함
Master Techs Master Techs 회원
Community
329 회원들
안내서 1,452개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 16
전체 시간: 2,153
