주요 콘텐츠로 건너뛰기
Removing the HP Elitebook 6930p WLAN Module
필요한 것
  1. Removing the HP Elitebook 6930p WLAN Module, Battery Removal: 1 단계, 이미지 3개 중 1개 Removing the HP Elitebook 6930p WLAN Module, Battery Removal: 1 단계, 이미지 3개 중 2개 Removing the HP Elitebook 6930p WLAN Module, Battery Removal: 1 단계, 이미지 3개 중 3개
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p WLAN Module, Keyboard: 2 단계, 이미지 3개 중 1개 Removing the HP Elitebook 6930p WLAN Module, Keyboard: 2 단계, 이미지 3개 중 2개 Removing the HP Elitebook 6930p WLAN Module, Keyboard: 2 단계, 이미지 3개 중 3개
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing the HP Elitebook 6930p WLAN Module: 3 단계, 이미지 3개 중 1개 Removing the HP Elitebook 6930p WLAN Module: 3 단계, 이미지 3개 중 2개 Removing the HP Elitebook 6930p WLAN Module: 3 단계, 이미지 3개 중 3개
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing the HP Elitebook 6930p WLAN Module: 4 단계, 이미지 3개 중 1개 Removing the HP Elitebook 6930p WLAN Module: 4 단계, 이미지 3개 중 2개 Removing the HP Elitebook 6930p WLAN Module: 4 단계, 이미지 3개 중 3개
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  5. Removing the HP Elitebook 6930p WLAN Module, WLAN (WiFi) Module: 5 단계, 이미지 3개 중 1개 Removing the HP Elitebook 6930p WLAN Module, WLAN (WiFi) Module: 5 단계, 이미지 3개 중 2개 Removing the HP Elitebook 6930p WLAN Module, WLAN (WiFi) Module: 5 단계, 이미지 3개 중 3개
    • Locate the WLAN module
    • Use a plastic spugder or similar to carefully remove the 3 antenna wires from the WLAN module.
    • The antenna wires are colour coded tabs on them for easy reinstallation so be sure to take note of the correct order. there are coloured tabs on the wires!
    • Remove the 2 M2.5×4.0 screws that secure the WLAN module into the laptop
    • With the screws removed the right hand end of the WLAN module will pop up. You may now simply remove the module from the edge connector.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Richdave
회원 가입일: 04/09/10
32,729 평판
안내서 30개를 작성함
Master Techs Master Techs 회원
Community
329 회원들
안내서 1,452개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 22
전체 시간: 8,555
