이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will show you how to locate and remove the WLAN (WiFi) module.
필요한 것
Flip laptop over and locate the battery release button
Push release button to the left to release battery and gently pull battery from the laptop
Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
Slide the retention clips toward the keyboard to release the keyboard
Locate the WLAN module
Use a plastic spugder or similar to carefully remove the 3 antenna wires from the WLAN module.
Remove the 2 M2.5×4.0 screws that secure the WLAN module into the laptop
With the screws removed the right hand end of the WLAN module will pop up. You may now simply remove the module from the edge connector.
다른 3명이 해당 안내서를 완성하였습니다.
