주요 콘텐츠로 건너뛰기
Removing the HP Elitebook 6930p modem card
필요한 것
  1. Removing the HP Elitebook 6930p modem card, Battery Removal: 1 단계, 이미지 3개 중 1개 Removing the HP Elitebook 6930p modem card, Battery Removal: 1 단계, 이미지 3개 중 2개 Removing the HP Elitebook 6930p modem card, Battery Removal: 1 단계, 이미지 3개 중 3개
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p modem card, Keyboard: 2 단계, 이미지 3개 중 1개 Removing the HP Elitebook 6930p modem card, Keyboard: 2 단계, 이미지 3개 중 2개 Removing the HP Elitebook 6930p modem card, Keyboard: 2 단계, 이미지 3개 중 3개
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing the HP Elitebook 6930p modem card: 3 단계, 이미지 3개 중 1개 Removing the HP Elitebook 6930p modem card: 3 단계, 이미지 3개 중 2개 Removing the HP Elitebook 6930p modem card: 3 단계, 이미지 3개 중 3개
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing the HP Elitebook 6930p modem card: 4 단계, 이미지 3개 중 1개 Removing the HP Elitebook 6930p modem card: 4 단계, 이미지 3개 중 2개 Removing the HP Elitebook 6930p modem card: 4 단계, 이미지 3개 중 3개
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  5. Removing the HP Elitebook 6930p modem card, Modem card: 5 단계, 이미지 2개 중 1개 Removing the HP Elitebook 6930p modem card, Modem card: 5 단계, 이미지 2개 중 2개
    • Locate the modem card and remove the 2 M2.5×4.0 screws
    • The modem card is it is plugged into a connector on the logic board. Gently lift the card up and out of the laptop
    • A plastic spudger may be useful in lifting the card out
    • Be careful as there is a small cable connected to the edge of the modem card closest to the LCD display
    • Disconnect the cable from the modem card to complete removal
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Richdave
회원 가입일: 04/09/10
32,371 평판
안내서 30개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,699개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 1,439
