주요 콘텐츠로 건너뛰기
Removing the Logitech MBJ58 Mouse Scroll Wheel
필요한 것
  1. Removing the Logitech MBJ58 Mouse Scroll Wheel, Top cover: 1 단계, 이미지 1/1
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
    باز کردن پیچ زیر موس
    h sh - 답글
    There may be a sticker covering the screw hole.
    Eric Jensen - 답글
  2. Removing the Logitech MBJ58 Mouse Scroll Wheel: 2 단계, 이미지 1/2 Removing the Logitech MBJ58 Mouse Scroll Wheel: 2 단계, 이미지 2/2
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
    جدا کردن قاب رو و زیر موس
    h sh - 답글
    The cover doesn’t lift straight up on my model - once you raise the back slightly as shown, gently pull it backward (parallel to the table top, away from the cord) to disengage two plastic clips that connect the bottom to the top.
    Eric Jensen - 답글
  3. Removing the Logitech MBJ58 Mouse Scroll Wheel, Removing the Logitech MBJ58 Mouse Scroll Wheel: 3 단계, 이미지 1/3 Removing the Logitech MBJ58 Mouse Scroll Wheel, Removing the Logitech MBJ58 Mouse Scroll Wheel: 3 단계, 이미지 2/3 Removing the Logitech MBJ58 Mouse Scroll Wheel, Removing the Logitech MBJ58 Mouse Scroll Wheel: 3 단계, 이미지 3/3
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
    خارج کردن چرخ اسکرول موس
    h sh - 답글
    Good information!
    My mouse is like new again.
    Many thanks
    Arie Dekker - 답글
결론
다른 5명이 해당 안내서를 완성하였습니다.
Conor Whatley
회원 가입일: 01/11/13
489 평판
안내서 3개 작성하였습니다
Cal Poly, Team 5-14, Forte Winter 2013 Cal Poly, Team 5-14, Forte Winter 2013 회원
CPSU-FORTE-W13S5G14
5 회원들
안내서 21개 작성하였습니다
댓글 2개
Thanks! The picture was what I needed after the mouse wheel parts came apart. My mouse is an M-BT58, but based on the numbers on the circuit board, there are probably several that are essentially the same. For others, here are some more details on putting things back together.
The mouse wheel has 4 parts:
1) The wheel itself (really a rubber tire and plastic rim, but they stay together)
2) Plastic carrier for the wheel
3) A spring for controlling rotation of the scroll wheel. This spring is at the top of the picture shown.
4) A spring for controlling clicks of the scroll wheel, shown near the wire leading to the computer.
Reassembly
1) Put spring (3) on carrier (2). There is a hole where the very tip of the end without the loop fits in.
2) Push the shorter axle of the mouse wheel into the carrier slightly depressing spring (3) as it is inserted. Once the wheel is inserted, the spring will stay in place.
3) Put spring (4) on the longer axle of the mouse wheel.
4) Install the carrier into the base of the mouse.
Jim Monte - 답글
I ran out of characters in the previous comment, but as you are installing the carrier into the base of the mouse, be sure to keep the spring (4) approximately as it is shown in the picture.
Jim Monte - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 38
전체 시간: 5,604
