주요 콘텐츠로 건너뛰기
Removing the Logitech MBJ58 Scroll Wheel from its Mount
필요한 것
  1. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Top cover: 1 단계, 이미지 1개 중 1개
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
  2. Removing the Logitech MBJ58 Scroll Wheel from its Mount: 2 단계, 이미지 2개 중 1개 Removing the Logitech MBJ58 Scroll Wheel from its Mount: 2 단계, 이미지 2개 중 2개
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
  3. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: 3 단계, 이미지 3개 중 1개 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: 3 단계, 이미지 3개 중 2개 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: 3 단계, 이미지 3개 중 3개
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
  4. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Support Spring: 4 단계, 이미지 2개 중 1개 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Support Spring: 4 단계, 이미지 2개 중 2개
    • Locate the spring on the scroll wheel, and carefully remove the spring.
  5. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Attaching the New Spring: 5 단계, 이미지 2개 중 1개 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Attaching the New Spring: 5 단계, 이미지 2개 중 2개
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
  6. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Wheel Mount: 6 단계, 이미지 3개 중 1개 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Wheel Mount: 6 단계, 이미지 3개 중 2개 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Wheel Mount: 6 단계, 이미지 3개 중 3개
    • Locate the black wheel mount.
    • Note: Make sure that the spring hidden in the mount does not fall out.
    • Separate the wheel from its mount.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Conor Whatley
회원 가입일: 01/11/13
510 평판
안내서 3개를 작성함
Cal Poly, Team 5-14, Forte Winter 2013 Cal Poly, Team 5-14, Forte Winter 2013 회원
CPSU-FORTE-W13S5G14
5 회원들
안내서 23개를 작성함
2가이드 댓글
Thank you! The photographs with good resolution and correct lighting made everything clear and comprehencible.
Антон Вакаренко - 답글
Very helpful, thank you!
K.S. - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 38
전체 시간: 2,002
