소개
In this guide, you will learn how to remove the stand for a Samsung C530 Series 5 LCD. The guide is very simple as there are only four screws to remove from the back of the TV itself
필요한 것
Place the TV face down on a clean flat surface with the stand hanging over one edge.
Remove the 4 screws securing the stand to the TV.
Holding the TV so it does not slide off the work surface, pull the stand straight out of the TV.
다른 20명이 해당 안내서를 완성하였습니다.
댓글 4개
What model # is this???!
What MODEL is this though ?!
Just got to say that it took me an 1:30 to take it off its sutch a bad design.
thank you so much
George Agius - 답글
Pichar problem
Sid sidharth gamer - 답글
Conviene desarmar la base retirada y volver al televisor la parte separada con sus 4 tornillos con lo que se tapa el agujero que queda en el proceso anterior.
Gracias
mario Baccaglioni - 답글
ποιο μοντέλο είναι η τηλεόραση στην φωτογραφία ;
Michael Gerakianakis - 답글
