주요 콘텐츠로 건너뛰기
Remplacement de l'écran tactile et du LCD du Samsung Galaxy A5 (2017)
필요한 것
동영상 지침
결승점
다른 40명이 해당 안내서를 완성하였습니다.
ian mdx
회원 가입일: 06/30/16
8,968 평판
안내서 17개 작성하였습니다
댓글 9개
Good video!
I have a question though. What did you use to bull back the back partbof the phone at the end of the video? You simply heated the glue that was already there?
Mattia Rappuoli - 답글
Please answer, what is the glue you used in the video? Thanks.
tcatt - 답글
The glue used here is the B7000 glue, which can be found on this site under tools or from aliexpress.com.
However, it should be mentioned that it is not required to use other glue than the sticky tape than phone already has, unless you are serious about waterproofing. I removed 98% of all the sticky tape that was there hoping it would be easier to open later. Funny thing is that I still have to use heat lol. Hard to remove all that sticky.
lightmeupper - 답글
The tool to pull back the cover is Suction Handle
Something tells me it may work with a 40-50mm diameter suction cup from dollar store as well :-)
lightmeupper - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 13
30일 전: 73
전체 시간: 68,328
