주요 콘텐츠로 건너뛰기
Jazz UltraTab C855 Screen Replacement
필요한 것
  1. Jazz UltraTab C855 Screen Replacement, Back Cover: 1 단계, 이미지 1/1
  2. Jazz UltraTab C855 Screen Replacement: 2 단계, 이미지 1/1
    • Pry the back case off using the blue Plastic Opening Tools. Work one along the seem until you can get your fingers under to pull it apart.
  3. Jazz UltraTab C855 Screen Replacement, Motherboard: 3 단계, 이미지 1/1
    • Remove the two pieces of tape securing the ribbon cables to the motherboard.
  4. Jazz UltraTab C855 Screen Replacement: 4 단계, 이미지 1/1
    • Remove the 3 screws at the top of the motherboard.
  5. Jazz UltraTab C855 Screen Replacement: 5 단계, 이미지 1/1
    • Using a plastic prying tool, lift open the latch that secures the ribbon cable next to the speaker.
    • Pull the ribbon cable out of its connector on the motherboard.
  6. Jazz UltraTab C855 Screen Replacement: 6 단계, 이미지 1/1
    • Use a plastic prying tool to disconnect the other ribbon cable from the motherboard. This cable belongs to the device's cameras.
  7. Jazz UltraTab C855 Screen Replacement: 7 단계, 이미지 1/1
    • Disconnect the large ribbon cable from the motherboard. Do this by unlocking the tabs on each side of the connector.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  8. Jazz UltraTab C855 Screen Replacement: 8 단계, 이미지 1/1
    • Snip the two sets of wires that are attached to the motherboard. Cut the wires as close to the board as possible. This will leave plenty of length to reattach the wires to the new board.
    • Skip this step if you are only removing the motherboard to replace the screen.
    • During reassembly, we recommend soldering or crimping the wires away from the motherboard contacts. You should avoid soldering directly to the motherboard unless absolutely necessary. To learn more about soldering, check out iFixit's Soldering Skills Guide
  9. Jazz UltraTab C855 Screen Replacement, Screen: 9 단계, 이미지 1/1
    • Remove the two screws securing the speaker using the Phillips #000 Screwdriver.
    • Remove the speaker and set it aside.
  10. Jazz UltraTab C855 Screen Replacement: 10 단계, 이미지 1/1
    • Carefully pry the display from the 9 white tabs that secure the display to the screen.
    • You may also need to peel back a piece of tape on one side to completely remove the assembly.
    • Be careful when removing the screen. A broken screen may produce shards of glass.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Peter Daum
회원 가입일: 09/16/15
174 평판
안내서 1개 작성함
IUPUI, Team 1-3, Baechle Fall 2015 IUPUI, Team 1-3, Baechle Fall 2015 회원
IUPUI-BAECHLE-F15S1G3
5 회원들
안내서 10개 작성하였습니다
댓글 한 개
Are the internal components glued to the back of the display? Is it absolutely ne essay to cut the wires connecting the battery?
Rongwey - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 666
